[Ja...] Posted May 28, 2019 Share Posted May 28, 2019 Hi, I am unsure of how to create the Theoretical Sharp corner needed in the image attached. It;s the corner of a large Rad and a straight FaceTheo Sharp Corner.PNG Link to comment https://qualityforum.zeiss.com/topic/18538-theoretical-sharp-corner/ Share on other sites More sharing options...
[Ja...] Posted May 28, 2019 Share Posted May 28, 2019 Try defining and measuring those two planes, then use the intersect function to create a line. You can then use this line to report your distance or whatever the callout may be. Link to comment https://qualityforum.zeiss.com/topic/18538-theoretical-sharp-corner/#findComment-104296 Share on other sites More sharing options...
[Ja...] Posted May 28, 2019 Author Share Posted May 28, 2019 The lower left side is a 8.690 Rad Link to comment https://qualityforum.zeiss.com/topic/18538-theoretical-sharp-corner/#findComment-104298 Share on other sites More sharing options...
[To...] Posted May 28, 2019 Share Posted May 28, 2019 Use an intersection construction with a circle and a plane. Tick the "wall" checkbox. Since this circle can intersect the plane in 2 places, look for a small blue x which will indicate where the intersection feature was created. If it is not correct, there are 2 Results button available. Try clicking the other Result button. You should be able to verify the information at the bottom. Link to comment https://qualityforum.zeiss.com/topic/18538-theoretical-sharp-corner/#findComment-104300 Share on other sites More sharing options...
[Ja...] Posted May 28, 2019 Author Share Posted May 28, 2019 Thanks Tom! That worked perfectly! 😃 😃 Link to comment https://qualityforum.zeiss.com/topic/18538-theoretical-sharp-corner/#findComment-104302 Share on other sites More sharing options...
