Theoretical Sharp Corner
Try defining and measuring those two planes, then use the intersect function to create a line. You can then use this line to report your distance or whatever the callout may be.
Use an intersection construction with a circle and a plane. Tick the "wall" checkbox. Since this circle can intersect the plane in 2 places, look for a small blue x which will indicate where the intersection feature was created. If it is not correct, there are 2 Results button available. Try clicking the other Result button. You should be able to verify the information at the bottom.
