[Me...] Posted May 2, 2019 Share Posted May 2, 2019 I am new to the Calypso software and have. I was wondering if there is a way to change the imported Cad view/lighting to eliminate the glare that is shown on the model when rotated normal to a surface. I've tried changing various color settings, such as the part color, from within the software and it helps a bit, but the glare is still very prominent and annoying. Link to comment https://qualityforum.zeiss.com/topic/18698-imported-cad-model-glare/ Share on other sites More sharing options...
[Ma...] Posted May 3, 2019 Share Posted May 3, 2019 Use CAD/ Settings/ Colors and you can change the color of the model, background, etc.. Mark Link to comment https://qualityforum.zeiss.com/topic/18698-imported-cad-model-glare/#findComment-105258 Share on other sites More sharing options...
[No...] Posted May 3, 2019 Share Posted May 3, 2019 No, there are no options to adjust the lighting. Try using darker colors for the part, this will also reduce the glare. Link to comment https://qualityforum.zeiss.com/topic/18698-imported-cad-model-glare/#findComment-105260 Share on other sites More sharing options...
[Al...] Posted May 3, 2019 Share Posted May 3, 2019 Unfortunately, there is no way the modify the transparency or brightness of the model, which would reduce the glare. Like Mark said, find a color that works better for your eyes. Link to comment https://qualityforum.zeiss.com/topic/18698-imported-cad-model-glare/#findComment-105262 Share on other sites More sharing options...
[To...] Posted May 3, 2019 Share Posted May 3, 2019 Please sign in to view this quote. If you go to CAD - Settings and change the Boundary Color to a contrasting color. I like dark gray. If you want to set this as a default setting, at the left, click Save & Load and click Save as System Setting. If you don't see the edges on the model, at the bottom of the CAD window, click the icon to the left of the Render (Show Model with CAD Surfaces) icon. This toggles the boundary settings. I think this will help you see the details that are washed out from the "glare". Link to comment https://qualityforum.zeiss.com/topic/18698-imported-cad-model-glare/#findComment-105264 Share on other sites More sharing options...
