Weird Zeiss server message in status window
Actually this is not an error message. CMM has one controller and when you use Gear Pro there is 2 software. This message is show with which software controller is controlled. Because of this always use Gear Pro icon on Calypso and Calypso icon on Gear Pro switching beetween Gear Pro and Calypso. This way Controller always knows which software has the control.
I also see these messages a lot. The connection is coming from a server of my company, which hasn't got anything to do with Calypso or measurements at all. Our IT guy once said something about it, but I don't remember.
To get the DNS name of the server, which may hint about its purpose, you can use the ping command:
Open cmd.exe and type ping -a <IP address>
In the example you would type ping -a 10.0.9.237
