[Wo...] Posted April 16, 2019 Share Posted April 16, 2019 Hi all, I've got a weird issue after upgrading to the latest Service Pack on 2018 6.6.16 If I load a CAD and don't move it, everything is fine. If I take a point, on the CAD surface, it appears where I clicked with the mouse. The problems start when I reposition the model with "CAD- Modify CAD entities - Positioning" menu After doing that, if I click on the model to take a point, it appears where it would be originally before moving. In the second picture I have clicked on the front face to take a point, and it appeared 2" in front of the part - that's where the front face originally was before moving. I have checked it on two different stations with the same result. Any ideas what may be causing it? Thanks, Wojtek Link to comment https://qualityforum.zeiss.com/topic/18732-problems-with-cad-after-moving-with-positioningquot/ Share on other sites More sharing options...
[Su...] Posted April 17, 2019 Share Posted April 17, 2019 Is the stylus correct or the stylus direction changing? Link to comment https://qualityforum.zeiss.com/topic/18732-problems-with-cad-after-moving-with-positioningquot/#findComment-105450 Share on other sites More sharing options...
[Th...] Posted April 17, 2019 Share Posted April 17, 2019 Do you have any instances of Calypso still on 6.6.12? While I wasn't moving CAD models around like you, I also had issues with misbehaving points on 6.6.16. I had to downgrade to fix them. Link to comment https://qualityforum.zeiss.com/topic/18732-problems-with-cad-after-moving-with-positioningquot/#findComment-105452 Share on other sites More sharing options...
[Wo...] Posted April 17, 2019 Author Share Posted April 17, 2019 The point's vector changes correctly, its just the location. And I don't have 6.6.12 installed anymore, but I know it was behaving correctly. It's not a deal breaker for me, as I usually rotate the part's model by setting spatial and planar rotations. This way it works correctly. However, if I subsequently add some fixture models I run into issues. There is a couple of fixes in 6.6.16 that I like so I won't be reverting 😉 Thanks for input! Link to comment https://qualityforum.zeiss.com/topic/18732-problems-with-cad-after-moving-with-positioningquot/#findComment-105454 Share on other sites More sharing options...
[Do...] Posted April 17, 2019 Share Posted April 17, 2019 I have this issue currently once you move the CAD away from the established Base alignment. It will generate points with the CAD surface, then relocate it to what seems like a random location. I established a temporary alignment and it resolved my problem, never had the issue prior to 6.6.12 though. kinda weird. 😃 Link to comment https://qualityforum.zeiss.com/topic/18732-problems-with-cad-after-moving-with-positioningquot/#findComment-105456 Share on other sites More sharing options...
[Ri...] Posted April 30, 2019 Share Posted April 30, 2019 I have found in a few features created from models there is a CAD Evaluation View being generated. Select a feature that is moving when selected, then check the menu: CAD / Evaluation. If there is a view saved, there will be a "Trash Can" icon in the lower middle area of the window frame. Delete the view. Link to comment https://qualityforum.zeiss.com/topic/18732-problems-with-cad-after-moving-with-positioningquot/#findComment-105458 Share on other sites More sharing options...
