[Ca...] Posted April 16, 2019 Share Posted April 16, 2019 Is it possible to manually assign a probe rotation position? I've never had an issue like this, but I have a large part, and Calypso keeps traveling to the upper Z limit, and red lighting, when it should be rotating the probe. There's plenty of room to the left and right, but it keeps traveling up. Thoughts? I think I've seen someone post something about this, but the search function on this forum always "ignores" most of the words I use to search. Link to comment https://qualityforum.zeiss.com/topic/18808-manual-probe-rotation-position/ Share on other sites More sharing options...
[Br...] Posted April 16, 2019 Share Posted April 16, 2019 Plan>Navigation>Rotate/Swivel Position Link to comment https://qualityforum.zeiss.com/topic/18808-manual-probe-rotation-position/#findComment-105852 Share on other sites More sharing options...
[Ca...] Posted April 16, 2019 Author Share Posted April 16, 2019 That sets a rotation point for every time the probe rotates, right? I just need it for this one time. Link to comment https://qualityforum.zeiss.com/topic/18808-manual-probe-rotation-position/#findComment-105854 Share on other sites More sharing options...
[Ca...] Posted April 16, 2019 Author Share Posted April 16, 2019 I just don't get it. If I rotate the probe to the desired orientation, it runs fine. When it needs to rotate itself, it just travels to the Z limit and stops. Link to comment https://qualityforum.zeiss.com/topic/18808-manual-probe-rotation-position/#findComment-105856 Share on other sites More sharing options...
