Customized PiWeb Reports
At the forum there are some questions for flexible PiWeb outputs.
In the attachment is an actual solution for such customized requests:
- multiple graphics in one sheet
- numerical values, like diameter, inside the graphic
- only show output, if characterisic is measured (according to MiniPlan)
- create only one PDF file (numerical & graphic)
- perspective view, if possible
PiWeb is "still under construction", therefore this example mirrors only the actual revsion CALYPSO 2018.
My opinion is, I know not all tricks, so I hope members of this forum will post additional solutions.
CALYPSO 2018, Curve & PCM
Test version
- unzip the inspection
- load stylus (ssc)
- try it and have fun
CustomizedPlott_CALYPSO_2018.zip
