Probe Length
I was completely unaware there were limits on this.
If I'm interpreting the graphic correctly, a TL3 in the "down" position cannot use a probe longer than 125mm? Is that because the probe is too great a distance from the qualification origin of the master probe?
I've had a couple of probes longer than this, which I made sure were within the weight requirements, but they've worked fine for me. Am I playing with fire?
https://qualityforum.zeiss.com/topic/18876-probe-length/#findComment-106252
  • 2 weeks later...
