2017 v6.4.24 bugs
I keep getting an error during the first attempt to move a CAD object.
Im setting up fixturing for a part, done this 1000's of times in v6.2.x, now v6.4.24 pops up an error on every first attempt to move a CAD object. The second attempt seems to work without the error.
I've attached a screen shot of the error and a text file of the error report if that can help solve this.
(edits)
Changed topic to 2017 V6.4.24 version bugs
Plannar and Step files error-1.jpgNew Text Document.txt
https://qualityforum.zeiss.com/topic/18968-2017-v6424-bugs/
I have a feature assigned to an alignment to report a depth.
When I run thru the program to generate a complete report the feature reports the value related to an alignment it was created from.
I have corrected the value several times by opening the characteristic, edit the feature, and closing. Once ran thru a CNC Run, it reverts back to the original alignment value.
See attached images
From original alignment.jpgFrom original alignment - edit mode.jpgFrom assigned alignment.jpg
https://qualityforum.zeiss.com/topic/18968-2017-v6424-bugs/#findComment-106774
