[Ri...] Posted March 25, 2019 Share Posted March 25, 2019 I keep getting an error during the first attempt to move a CAD object. Im setting up fixturing for a part, done this 1000's of times in v6.2.x, now v6.4.24 pops up an error on every first attempt to move a CAD object. The second attempt seems to work without the error. I've attached a screen shot of the error and a text file of the error report if that can help solve this. (edits) Changed topic to 2017 V6.4.24 version bugsPlannar and Step files error-1.jpgNew Text Document.txt Link to comment Share on other sites More sharing options...
[Ri...] Posted March 25, 2019 Author Share Posted March 25, 2019 When selecting features (In this case a circle) and Clipping Plane is active, I get the inverse of the feature ( An ID becomes OD) and the physical location selected is shifted along its axis an unknown value. With Clipping Plane off, selection appears to work properly. Link to comment Share on other sites More sharing options...
[Ri...] Posted March 25, 2019 Author Share Posted March 25, 2019 I have a feature assigned to an alignment to report a depth. When I run thru the program to generate a complete report the feature reports the value related to an alignment it was created from. I have corrected the value several times by opening the characteristic, edit the feature, and closing. Once ran thru a CNC Run, it reverts back to the original alignment value. See attached imagesFrom original alignment.jpgFrom original alignment - edit mode.jpgFrom assigned alignment.jpg Link to comment Share on other sites More sharing options...
[Me...] Posted March 26, 2019 Share Posted March 26, 2019 I some how remember an old "007" movie where the bad guy talks to his I.T. people about the latest release of some mega software. The response is that it was successful with enough bugs to generate cash flow for several years. Link to comment Share on other sites More sharing options...
[Me...] Posted March 26, 2019 Share Posted March 26, 2019 Boy....I just noticed there are several posts I could reply to with my comment!! Link to comment Share on other sites More sharing options...
