[Ma...] Posted March 12, 2019 Share Posted March 12, 2019 Does anyone know why my arrows are skewed I tried different probes and requalifying everything? thank you[img][/img]arrrows.png Link to comment https://qualityforum.zeiss.com/topic/19018-result-arrows-skewed/ Share on other sites More sharing options...
[Te...] Posted March 12, 2019 Share Posted March 12, 2019 If you are using a Star Probe on an XXT that may be normal. If you are not I am guessing you maybe going to fast. Link to comment https://qualityforum.zeiss.com/topic/19018-result-arrows-skewed/#findComment-107056 Share on other sites More sharing options...
[Cl...] Posted March 12, 2019 Share Posted March 12, 2019 What is the surface finish on that edge? If it's too rough, that could be the issue. Link to comment https://qualityforum.zeiss.com/topic/19018-result-arrows-skewed/#findComment-107058 Share on other sites More sharing options...
[Kl...] Posted March 13, 2019 Share Posted March 13, 2019 Hello Clark It's typical for scanning run. There are two force directions stored by the Controller: - 1st Measuring force perpenticular to surface - 2nd friction parallel to moving path The effect is a tilted actual force vector which is normal for sanning regards Klaus Link to comment https://qualityforum.zeiss.com/topic/19018-result-arrows-skewed/#findComment-107060 Share on other sites More sharing options...
[Cl...] Posted March 13, 2019 Share Posted March 13, 2019 Thanks, guess I never actually paid that close attention to it. Link to comment https://qualityforum.zeiss.com/topic/19018-result-arrows-skewed/#findComment-107062 Share on other sites More sharing options...
[Am...] Posted March 19, 2019 Share Posted March 19, 2019 While it is normal to see something like this I believe that feature is being measured too fast, if you slow down your scanning speed I think you would see the vectors would straighten out a bit more. Link to comment https://qualityforum.zeiss.com/topic/19018-result-arrows-skewed/#findComment-107064 Share on other sites More sharing options...
