NAME STRUCTURE NOT SHOWING IN PLANE OR LINE FEATURE
It is my understanding that a feature will show under the comment button only when there could be confusion as to which type of feature you are measuring. For example, you may take points and the software thinks you want a cylinder when you actually want a circle. Two points define a line/three points define a plane; if you take more than two it'll default to a plane.
If you have PC-DMIS experience, you will recognize this as similar to their "Guess Feature" option. They determine what they think you are trying to do and you have the option to override.
