[Me...] Posted March 12, 2019 Share Posted March 12, 2019 Is there a way to default the Filter/Outlier setting to Gauss? For some reason mine is set to spline... Link to comment https://qualityforum.zeiss.com/topic/19066-gauss-filter/ Share on other sites More sharing options...
[Te...] Posted March 12, 2019 Share Posted March 12, 2019 Yes and No, it would be nice though if it was the default. You can go to Resources/Save/Load Defaults/Filter/Outlier tab and turn it on there but that only does the characteristic side. Since the Cookbook I do all filtering on the feature side so this doesn't help much. I use the Transfer Tool a lot now for transferring the evaluations so I only set a few and then transfer. Link to comment https://qualityforum.zeiss.com/topic/19066-gauss-filter/#findComment-107320 Share on other sites More sharing options...
