Recalling Curves into Curves
We figured it out last summer in a class but I still have issues with it.
You have to make sure you uncheck recalculate nominals then select all your curves and then change it to actual to nominal input after opening and closing the window.
No matter how you select the curves it still jumbles all the points and you spend more time reversing point numbers and vectors...
It's mind-numbing work.
  • 3 weeks later...
Hello
as I understand you want calculate curves by different conditions e.g. with or without bestfit.
Normally I have a feature to collect the meaured values (like helical cylinder)
- 1st Curve with radial normal vectors calculates the radial behaivour
- 2nd Curve with axial normal vectors the slope (thread).
For both curves you can use recalled points from cylinder
CALYPSO always checks "NOMINAL exits? YES/NO"
If "No" new nominal are created by recalled measured values => ball center, normal vectors by "crassy" tangents
Summary
Additional identical curves with same nominal and same actuals (recalled) and various elvaluation conditions
Grettings
Klaus
