REPORTING MIN AND MAX POSITION RESULTS
We have many parts with MANY (up to 200) tapped holes Positioned to the minor diameter to (for example) -A-B-C-. These days I'm seeing composite DRF's to best fit the pattern as well.
Is there a quick way to report the Min and Max Position results, instead of reporting all 200 holes with a Bore Pattern? Using the Min and Max Result doesn't work if you select the Bore Pattern.
Thanks in advance.
https://qualityforum.zeiss.com/topic/19178-reporting-min-and-max-position-results/
Wait! its not the bore pattern name, its the characteristic name for the position of the bore pattern. I just tested it on one of my programs with real data and it works. Maybe try to actually run one, and verify that it does actually pick the maximum and minimum error.
No, all position tolerances are at .004. If I switch the Dimension type from Number to Length, I get .0034 for my Min and .024 for my Max; The actual positions for the best fit pattern are all under .001.
I created the program off-line in 6.4, with compatibility settings set for 5.4.12, which is what we run on the machines. I have new computers loaded with 6.4 to swap out but big wheels turn slow around here. Don't know if that's the culprit or not.
