[Me...] Posted February 21, 2019 Share Posted February 21, 2019 Does anyone know how to export a separate txt file for all features that only shows x,y,z,i,j,k data? So for a cylinder it would have the xyzijk values for every point taken. Link to comment https://qualityforum.zeiss.com/topic/19236-hopefully-easy-question/ Share on other sites More sharing options...
[No...] Posted February 22, 2019 Share Posted February 22, 2019 Easy answer: Yes. There's an export points option in result output section. It can also be automated. But I can't describe it in detail out of memory (I'm not near a Calypso seat at the moment) Link to comment https://qualityforum.zeiss.com/topic/19236-hopefully-easy-question/#findComment-108250 Share on other sites More sharing options...
[Me...] Posted February 22, 2019 Author Share Posted February 22, 2019 After every run, Calypso provides 3 text files: hdr, fet, and char. I've played with all the settings, but these are the only text files that I seem to be able to create. Using Calypso2015 without any additional add-ons. Link to comment https://qualityforum.zeiss.com/topic/19236-hopefully-easy-question/#findComment-108252 Share on other sites More sharing options...
[No...] Posted February 22, 2019 Share Posted February 22, 2019 This is how to do it in CNC mode: - Go to Resources / Results to File - Set "Export Points" to On - Click "Configuration" Button - Make the desired settings. - Go to Resources / Features Settings Editor - Select Geometry (Setting of Evaluation) / Export Points - Set desired features to On or select whole measurement plan. You can also export a point file for a single feature from the context menu. The settings are the same. P.S.: I forgot to verify where the files are being stored. They should be in the measurement plan folder or in the results folder. Maybe in a subfolder (points, actuals, geoactuals or something like that). Link to comment https://qualityforum.zeiss.com/topic/19236-hopefully-easy-question/#findComment-108254 Share on other sites More sharing options...
[Me...] Posted February 22, 2019 Author Share Posted February 22, 2019 Wow, turns out that I was doing it all along, I just didn't know where the files were being saved. For me, it made an "PointsExport" folder inside the inspection folder. Thanks for your help! Link to comment https://qualityforum.zeiss.com/topic/19236-hopefully-easy-question/#findComment-108256 Share on other sites More sharing options...
