[Me...] Posted February 21, 2019 Share Posted February 21, 2019 Does anyone know how to export a separate txt file for all features that only shows x,y,z,i,j,k data? So for a cylinder it would have the xyzijk values for every point taken. Link to comment Share on other sites More sharing options...
[No...] Posted February 22, 2019 Share Posted February 22, 2019 Easy answer: Yes. There's an export points option in result output section. It can also be automated. But I can't describe it in detail out of memory (I'm not near a Calypso seat at the moment) Link to comment Share on other sites More sharing options...
[Me...] Posted February 22, 2019 Author Share Posted February 22, 2019 After every run, Calypso provides 3 text files: hdr, fet, and char. I've played with all the settings, but these are the only text files that I seem to be able to create. Using Calypso2015 without any additional add-ons. Link to comment Share on other sites More sharing options...
[No...] Posted February 22, 2019 Share Posted February 22, 2019 This is how to do it in CNC mode: - Go to Resources / Results to File - Set "Export Points" to On - Click "Configuration" Button - Make the desired settings. - Go to Resources / Features Settings Editor - Select Geometry (Setting of Evaluation) / Export Points - Set desired features to On or select whole measurement plan. You can also export a point file for a single feature from the context menu. The settings are the same. P.S.: I forgot to verify where the files are being stored. They should be in the measurement plan folder or in the results folder. Maybe in a subfolder (points, actuals, geoactuals or something like that). Link to comment Share on other sites More sharing options...
[Me...] Posted February 22, 2019 Author Share Posted February 22, 2019 Wow, turns out that I was doing it all along, I just didn't know where the files were being saved. For me, it made an "PointsExport" folder inside the inspection folder. Thanks for your help! Link to comment Share on other sites More sharing options...
