[Fa...] Posted February 11, 2019 Share Posted February 11, 2019 I followed Roberto's steps to put the sound at the end of the program and it worked perfectly. Now I have a question: How do I put the sound effect on a program to stop in the middle of the program? Link to comment https://qualityforum.zeiss.com/topic/19312-calypso-sound-effects-part-ii/ Share on other sites More sharing options...
[Ro...] Posted February 12, 2019 Share Posted February 12, 2019 I figure you have PCM...... You can Re-Ring the same bell or you can create a new sound and use a new BAT file, whatever you prefer. It's kinda fun searching thru soundboards in the sketchy part of the internet for a half a day on company time. So if you have a spot in your program where you have a program stop, maybe in the presettings of the feature you have the stop, or maybe the post settings of the previous feature, you can use system call to activate the bat file. Copy the text and just edit the file name & path to fit your needs. systemCall("C:\Users\Public\Documents\Zeiss\CALYPSO 6.6\workarea\inspections\inspection_end.bat") Link to comment https://qualityforum.zeiss.com/topic/19312-calypso-sound-effects-part-ii/#findComment-108670 Share on other sites More sharing options...
[Fa...] Posted February 13, 2019 Author Share Posted February 13, 2019 Thanks, roberto Yes, I have PCM. But where do I place the command line? Link to comment https://qualityforum.zeiss.com/topic/19312-calypso-sound-effects-part-ii/#findComment-108672 Share on other sites More sharing options...
[Ro...] Posted February 13, 2019 Share Posted February 13, 2019 Ok, on the last feature to run before your program stop, click on the feature so it turns grey, then up at the top of the feature column click on the peach colored P. A parameter box will pop up, put the command in the bottom section (postsettings) of that box. FYI, the 2 boxes are Presettings & Postsettings, something in the top will execute before the feature runs, something in the bottom will execute after the feature runs. Link to comment https://qualityforum.zeiss.com/topic/19312-calypso-sound-effects-part-ii/#findComment-108674 Share on other sites More sharing options...
[Fa...] Posted February 13, 2019 Author Share Posted February 13, 2019 Perfect. Tks Link to comment https://qualityforum.zeiss.com/topic/19312-calypso-sound-effects-part-ii/#findComment-108676 Share on other sites More sharing options...
