[Su...] Posted February 6, 2019 Share Posted February 6, 2019 Hello guys please tell me how to take cmm position after checking a feature. I tried with one option in strategy-> position cmm without probing.but I want to make position with functional keys on the controller box/joystick box. And Additionally can anyone tell tricks for using control box functional keys (like F2 uses for deleting probing points).any combination keys etc. Thanks in advance. Link to comment https://qualityforum.zeiss.com/topic/19342-cmm-position/ Share on other sites More sharing options...
[To...] Posted February 6, 2019 Share Posted February 6, 2019 With the feature open, move the stylus to the desired position and press the button on top of the right joystick. That will put in a position point. If you add it via the icon in the strategy window, you can edit its' location in the point list. Double-click any of the points in the strategy list and this will open the points list. Be aware of "Coordinates Relative to" setting. Actually F3 deletes probing points on the joystick controller. F8 now starts the run of a program. If the traffic is red, it will prompt you if you want it to change to green. Then, will open run window. F11 will begin 4 point circle macro used to create a circle. I think the attached document is for distribution. It should be. Admin please let me know if is not,Joystick Controller_26SE_en.pdf Link to comment https://qualityforum.zeiss.com/topic/19342-cmm-position/#findComment-108798 Share on other sites More sharing options...
[Su...] Posted February 6, 2019 Author Share Posted February 6, 2019 Please sign in to view this quote. Thank you sir this is greatly helpful for me Link to comment https://qualityforum.zeiss.com/topic/19342-cmm-position/#findComment-108800 Share on other sites More sharing options...
[Su...] Posted February 6, 2019 Author Share Posted February 6, 2019 Please sign in to view this quote. Sorry it was my mistake, actually it's F3. Link to comment https://qualityforum.zeiss.com/topic/19342-cmm-position/#findComment-108802 Share on other sites More sharing options...
[Su...] Posted February 7, 2019 Author Share Posted February 7, 2019 Please sign in to view this quote. I tried it but it's not working ( move to desired place/position, and press button on top of right joystick) Link to comment https://qualityforum.zeiss.com/topic/19342-cmm-position/#findComment-108804 Share on other sites More sharing options...
[Me...] Posted February 7, 2019 Share Posted February 7, 2019 How do you set your clearance plane cube? If you use the joystick button, it's the same thing. But just press once. Link to comment https://qualityforum.zeiss.com/topic/19342-cmm-position/#findComment-108806 Share on other sites More sharing options...
[Su...] Posted February 7, 2019 Author Share Posted February 7, 2019 Please sign in to view this quote. Ok when was I press that button, before or after creating Clarence plane cube.and when feature take manual probing how it's working. Link to comment https://qualityforum.zeiss.com/topic/19342-cmm-position/#findComment-108808 Share on other sites More sharing options...
