Using Result element instead of Text Element
I have a lot of text elements to display values for our print out reports, of course now they do not print in PiWeb (Yay....NOT)
I have now setup Result Elements which will display and print in PiWeb.
What I need to do now is be able to pass a specific value to the result element so the operator doesn't have to type in a value (don't want typing errors).
The result element will pop up a dialog box at run time prompting the operator to input a value then click on th e"OK" button.
I would like to know if PCM can process the actions programmatically?
See attached image.
Im not saying that you can't use pcm to press your ok button, but why make it so complicated? Why do you wish to press the button?
May I suggest that you instead, untick result input and tick compute formula instead. Place a variable there that contains you value.
  • 3 weeks later...
