[Me...] Posted January 3, 2019 Share Posted January 3, 2019 i initially have two Questions about the profile function. 1. i have a profile of .002 that only references one datum. In calypso when i try to put in ONLY the datum it wants it measured too, it gives me an error. how do i solve this? 2. the feature is a aligning the halves of a slot, [ ] is there a way to combine 3 sides into one profile Characteristic? Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/ Share on other sites More sharing options...
[Cl...] Posted January 3, 2019 Share Posted January 3, 2019 1] Try creating a secondary alignment, and use that instead of pulling in a single datum. 2] Do you have Free Form Surface? If you do, you can use CAD - Creating Features - Point Set. Then create the FFS from faces. Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110382 Share on other sites More sharing options...
[Me...] Posted January 3, 2019 Author Share Posted January 3, 2019 Please sign in to view this quote. alright, turns out i don't have the free form option. its grayed out. to create a secondary alignment do i just create a new base alignment? and use the standard method? it doesn't seem like start alignment is right choice. Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110384 Share on other sites More sharing options...
[Me...] Posted January 3, 2019 Author Share Posted January 3, 2019 i think i found what i need in the help menu, but when i go to change base alignment and click special i don't get load secondary alignment option. Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110386 Share on other sites More sharing options...
[Ja...] Posted January 3, 2019 Share Posted January 3, 2019 David, I think Clarke is recommending that you create a new alignment, and then in the profile evaluation, select the alignment instead of the datum. To create a new alignment, go to [Resources] -> [Utilities] -> [Alignment]. Then, in your profile evaluation, above the datum selection there should be a drop down menu that you can navigate and select your newly created alignment. Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110388 Share on other sites More sharing options...
[Me...] Posted January 3, 2019 Author Share Posted January 3, 2019 alright, that looks better, so now i only want one datum. Do i select the face on the cad and then just click ok? is it that simple? Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110390 Share on other sites More sharing options...
[Ja...] Posted January 3, 2019 Share Posted January 3, 2019 The datum feature will already be measured, correct? If so, align your coordinate system (in the newly created alignment) to the datum (using the origin) in whichever directions the deviation is to be measured in. Complete the alignment as you did with your base alignment. Then, in the profile window, you can just select the alignment and be done. You will not have to explicitly select a datum at that point, as it'll be treating the alignment components (your datum) as the datum. Does that help? Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110392 Share on other sites More sharing options...
[Cl...] Posted January 3, 2019 Share Posted January 3, 2019 If for example the "one" datum is a plane (XY) then spatial rotate and origin (Z) the plane in the alignment window. Sorry David if I'm a little vague. Sometimes I assume everyone is up to speed with Calypso, so I tend to leave out minor details. If this is a multi surface feature that needs evaluated for Surface profile, I don't have any other suggestion that will work without FFS. Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110394 Share on other sites More sharing options...
[Me...] Posted January 3, 2019 Author Share Posted January 3, 2019 also Datum A is on the Bottom and B is on the Far left in Calypso i have Z pointing Straight up and X to the right and Y going forward the same way the part is positioned in the print. Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110396 Share on other sites More sharing options...
[Me...] Posted January 3, 2019 Author Share Posted January 3, 2019 Maybe im saying this wrong.. i call each letter a Datum. Datum A,B,C and soo on.. but im guessing thats wrong.. im hoping the picture helps with what im saying Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110398 Share on other sites More sharing options...
[Me...] Posted January 3, 2019 Author Share Posted January 3, 2019 Just to add: If the single primary datum doesn't constrain all 6 degrees of freedom, you'll probably want to do a best fit alignment and allow translation/rotation for the unconstrained DOF to use all allowable tolerance. Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110400 Share on other sites More sharing options...
[Ja...] Posted January 3, 2019 Share Posted January 3, 2019 Please sign in to view this quote. You are correct in saying that the letters are the Datums. If you can measure the feature and the Datum, as Clarke suggested make a new separate alignment aligning to the Datum in whichever axes are appropriate (and secure your other DOF as appropriate), and use that alignment in the profile evaluation window through the drop down. Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110402 Share on other sites More sharing options...
[Me...] Posted January 3, 2019 Author Share Posted January 3, 2019 Please sign in to view this quote. using best fit alignment worked thank you. Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110404 Share on other sites More sharing options...
[Me...] Posted January 3, 2019 Author Share Posted January 3, 2019 Glad it helped. 🙂 Link to comment https://qualityforum.zeiss.com/topic/19624-profile-of-surface/#findComment-110406 Share on other sites More sharing options...
