Measurement Plan Information
When adding setup pictures in the Measurement Plan Information tab, I combine multiple pictures into a PDF instead of a Power Point Presentation. I've noticed with either method that the picture quality declines...
Does anyone know a better method in which the picture quality is better?
Put the pictures in a Microsoft word document.
For some reason it holds a higher resolution.
Plus you can type instructions and have a wide range of picture editing tools, arrows, speech bubbles, highlight, mirror, etc, ect.
If I create measurement plane on offline computer, I put PDF instruction in to measurement plane folder. After that I send it to archive and put to the server. Operator load archive, unzip it and save to CMM computer. Will user information work after all this manipulation? Full name folder on offline and on CMM can be different.
Yes. I typically save all plan related items in the Measurement Plan folder. Then, when I want to transfer program to a different location, I just grab the MP folder and drag it wherever I want it. Zipping it when I need to.
