Newest 6.4 patch won't install.
You didn't mention it, so I must ask: Did you install SP 6.4.20 before applying the patch?
This is not a license issue. Valid licenses do not expire (the SMA may expire, but not the license) and are good for every service pack and patch within the same main revision (6.4 in this case)
  • 2 months later...
Excuse my ignorance as I am still new to the whole upgrade/update stuff.
From your comment, am i correct that if my SMA is expired, I can update (patches, service packs) for my current version (2017) but I can not upgrade to the newest version (2018).
This is correct. If your SMA expired after you received a license for 2017, you will still be allowed to install all service packs and patches for 2017. You would still be able to install 2018 as well, but without a valid license you would not be able to run it.
I am getting this same error while trying to download the latest patch for 6.6. I do not have any service packs installed since installing 2018. I don't see any either though??
not for me..
full version
patch
PTB certificates
are the only options i have in my drop down and i selected the categories the same as you had.
I am for sure running 6.6 no pack installed I double checked.
