Square datum
I have a part with a 0.500" square post that's a datum. Does Calypso have any feature recognition for a square?
I'm currently just scanning each face, and creating symmetry planes of the left/right and top/bottom, then intersecting the symmetry planes, and call that intersection my datum.
Caly 2017
No PCM
No CURVE
That's how I've handled it in the past.
But yeah it seems like there should be a way to recognize a Polygon of any given amount of sides.
a while ago I wrote a program for a sister plant looking for the TP of a small hex. i ended up scanning it as a circle with pretty good results compared to hard gauges.(hex is done on a 2nd op and isn't clocked to some other features)
luckily the end costumer doesn't have a receiving inspection cmm, so they wont be questioning my methods.
I wonder if you could scan a square post as a circle.
nominal diameter being the average between cross flats & cross corners, speed very slow.
probably not worth the hassle..........
