[Me...] Posted December 4, 2018 Share Posted December 4, 2018 I am trying to make a simple measurment but can't seem to get it right. I will attach a picture of of The measurment I'm trying to get. Mainly a measurement that is perpendicular to a tiny plane to my zero intersection. See PDF. Thanksperpendicular measurment.pdf Link to comment Share on other sites More sharing options...
[Ma...] Posted December 4, 2018 Share Posted December 4, 2018 Create a intersection at the point and measure the small plane. Add a Cartesian Distance selecting the point as feature 1 and the plane as feature 2. In Cartesian Distance the distance between a point and a plane will make them perpendicular. Mark Link to comment Share on other sites More sharing options...
[Cl...] Posted December 4, 2018 Share Posted December 4, 2018 Not a very wide plane, how long is it? Spread the plane points out as far as you can, spatial rotate and Z origin the plane, then intersect the corner for the1.6967 in Z, should be that simple, unless I'm missing something? Link to comment Share on other sites More sharing options...
[Cl...] Posted December 4, 2018 Share Posted December 4, 2018 Oop's, I think we were typing at the same time. Link to comment Share on other sites More sharing options...
[Me...] Posted December 4, 2018 Author Share Posted December 4, 2018 Mark, I'm using Calypso 2018 it seems buggy. I picked the intersection for the first feature and when I go to the second feature the plane isn't listed. If I go back to feature 1 and change it to the intersection, then I can select the plane. The nominal value for this Cartesian distance is Right 1.69668, but the actual is 2.02207 and when I run the program it says the measured value is 1.46380 in piweb. When I ran the program it measured the 2 planes that make the intersection and the small plane . And those were my results. Am I missing something? Link to comment Share on other sites More sharing options...
[An...] Posted December 5, 2018 Share Posted December 5, 2018 Please sign in to view this quote. Not long enough. See attached.Dist_Intersect_Plane_1.pdf Link to comment Share on other sites More sharing options...
[Ma...] Posted December 5, 2018 Share Posted December 5, 2018 Because the plane is so small you might want to create a new alignment at the intersection and rotate it to the planes nominal angle. Now take a point on this plane and use the Simple Distance characteristic to get the proper distance, making sure to change the alignment from base alignment to the new alignment. Mark Link to comment Share on other sites More sharing options...
[Me...] Posted December 5, 2018 Author Share Posted December 5, 2018 You may want to create an intersection, a rotated alternate alignment, take a point on the plane, using your alignment for the point and get your Cartesian result. Link to comment Share on other sites More sharing options...
