Perpendicular measurements from a plane
Create a intersection at the point and measure the small plane.
Add a Cartesian Distance selecting the point as feature 1 and the plane as feature 2. In Cartesian Distance the distance between a point and a plane will make them perpendicular.
Mark
Not a very wide plane, how long is it?
Spread the plane points out as far as you can, spatial rotate
and Z origin the plane, then intersect the corner for the1.6967
in Z, should be that simple, unless I'm missing something?
Mark, I'm using Calypso 2018 it seems buggy. I picked the intersection for the first feature and when I go to the second feature the plane isn't listed. If I go back to feature 1 and change it to the intersection, then I can select the plane. The nominal value for this Cartesian distance is Right 1.69668, but the actual is 2.02207 and when I run the program it says the measured value is 1.46380 in piweb. When I ran the program it measured the 2 planes that make the intersection and the small plane . And those were my results. Am I missing something?
Because the plane is so small you might want to create a new alignment at the intersection and rotate it to the planes nominal angle. Now take a point on this plane and use the Simple Distance characteristic to get the proper distance, making sure to change the alignment from base alignment to the new alignment.
Mark
You may want to create an intersection, a rotated alternate alignment, take a point on the plane, using your alignment for the point and get your Cartesian result.
