[Ni...] Posted December 4, 2018 Share Posted December 4, 2018 So I just this year started learning Calypso and CMM training. And I went to a basic class, and the instructor said Zeiss highly recommends changing filters and outliers on the characteristics side and not the features side so to not eliminate all the data filtered through the feature side. Has anybody any knowledge or experience changing the filters/ outliers on the characteristics side vs the feature side and how much would it help/ hurt or no change? Link to comment Share on other sites More sharing options...
[Cl...] Posted December 4, 2018 Share Posted December 4, 2018 Yes, this is the best way to go (IMHO) you generally start out with a LSQ feature and then change it to suit your particular evaluation needs, i.e. size/form/position. Not sure about the before/after on applying outliers? Link to comment Share on other sites More sharing options...
[Ni...] Posted December 4, 2018 Author Share Posted December 4, 2018 That's good to hear, because it would be time efficient to not have to change outliers and filters on the features side. I'd like to turn on the default settings for filters/outliers. But then another obstacle I've found is that in the default settings I cannot (or don't know) how to set my "Pre-filter for Outlier Recognition" to "Undulations Per Revolution" and set it to 10 - 5000. Also I also meant outliers when I was saying filters, sorry 😕 Link to comment Share on other sites More sharing options...
[Cl...] Posted December 4, 2018 Share Posted December 4, 2018 For undulations per revolution........for diameters 8mm or smaller set it to 15, larger than 8mm set to 50 Link to comment Share on other sites More sharing options...
[Mi...] Posted December 4, 2018 Share Posted December 4, 2018 IF I understand you correct this would solve your issue. Resources>>Save/Load Defaults. In the pop up window, check the box to turn on the filter, (highlighted below) then Click the gear icon and change your parameters. Then Save it out whatever name you want. Done Link to comment Share on other sites More sharing options...
[Ni...] Posted December 4, 2018 Author Share Posted December 4, 2018 Thank You but what I mean is I cant set a default UPR https://postimages.org/ Link to comment Share on other sites More sharing options...
[Ja...] Posted December 4, 2018 Share Posted December 4, 2018 I have the same issue. You can set the default values for prefilter Undulations per revolution and wavelength but it always goes to wavelength even if it is a circle or cylinder. It don't bother me much because I always go though the filter settings and outlier elimination to make sure they right based on the cook book and the feature size. And, if I have multiple features/characteristics that are similar I use the paint brush to apply the settings to the rest of the features/characteristics. Link to comment Share on other sites More sharing options...
