[Ha...] Posted August 22, 2018 Share Posted August 22, 2018 Hi, Is there a way to get the CNC to break or inspection to end when you press the close button (x) on windows like inquireParameterList or confirm..? Thanks! Hanna Link to comment https://qualityforum.zeiss.com/topic/19890-cncbreak-by-closing-inquireparameterlist/ Share on other sites More sharing options...
[Er...] Posted August 22, 2018 Share Posted August 22, 2018 Yes, a simple way is to check if the variable you are asking for has changed from the initial value. And use endInspection() instead of cncBreak(), that one is so "violent". orka="defalutValue" inquireParameterList("orka","a comment") if orka == "defalutValue" endInspection() endif But the confirm dialog requires a yes or no answer, the x is inactive, isn't it? If you know how to, you can make use of the dialog class, and make a answer required to be able to proceed. But that's overkill. Link to comment https://qualityforum.zeiss.com/topic/19890-cncbreak-by-closing-inquireparameterlist/#findComment-112282 Share on other sites More sharing options...
[Ha...] Posted November 26, 2018 Author Share Posted November 26, 2018 Thanks for your reply Eric! (I didn't notice I got an snswer until now) The problem is that 95 % of the time, the parameters will not change. I will only confirm that the variables are the same. You are right regarding the inactive x with confirm dialog. Link to comment https://qualityforum.zeiss.com/topic/19890-cncbreak-by-closing-inquireparameterlist/#findComment-112284 Share on other sites More sharing options...
