Help Me.
Good night,
I wonder if using point in space or some other method could make the measurement according to this drawing:
C leveling
Alignment in B
Origin in A
I was asked to check out these highlights.
Is it possible to measure in calypso without some extension?
thankful
[img]https://imageshack.com/a/img923/7892/dyfmCl.jpg[/img]
https://qualityforum.zeiss.com/topic/19902-help-me/
I'm not 100% sure what you mean by 'Extension', but i have a family of parts where i do a profile of a milled surface only using points.
The reason for this method is the size of the part, for context the part will sit inside a diameter the size of a nickel
We had very good luck using this method, known bad parts (setup or missload) scanned bad every time.
https://qualityforum.zeiss.com/topic/19902-help-me/#findComment-112370
