[Za...] Posted November 1, 2018 Share Posted November 1, 2018 Today I check program witch write my college and see one problem. List of collision after running in simulator is clean, but i see one trajectory from part. I re run this plane in very slow speed and see collision (in a picture) but calypso don't detect it again. it will be nasty collision and I fink stylus broke if it was on CMM. Have some body idea why it is not detected?colision.PNG Link to comment https://qualityforum.zeiss.com/topic/20006-calypso-dont-see-collision/ Share on other sites More sharing options...
[Ow...] Posted November 1, 2018 Share Posted November 1, 2018 Sorry Zvcyalov, I don't have much experience with simulation. Does Calypso know that the rest pad is there? Link to comment https://qualityforum.zeiss.com/topic/20006-calypso-dont-see-collision/#findComment-112932 Share on other sites More sharing options...
[Me...] Posted November 1, 2018 Share Posted November 1, 2018 I don't have experience either but that looks like a polyline !? It would seem to me that your asking Calypso to break it up. Link to comment https://qualityforum.zeiss.com/topic/20006-calypso-dont-see-collision/#findComment-112934 Share on other sites More sharing options...
[To...] Posted November 1, 2018 Share Posted November 1, 2018 Please sign in to view this quote. The blue line is a tracing line to show you were you've been. Based on the picture, Calypso should have shown there was a collision. Did you create the stylus system from "standard" styli or did you build a custom styli? If the latter, I'm wondering if Calypso is having trouble seeing it. Link to comment https://qualityforum.zeiss.com/topic/20006-calypso-dont-see-collision/#findComment-112936 Share on other sites More sharing options...
[Me...] Posted November 1, 2018 Share Posted November 1, 2018 Zvcyalov, It sounds like you've used this probe before. At least that was what I assumed. Like I said I don't do simulation. Though I do understand the blue line. Link to comment https://qualityforum.zeiss.com/topic/20006-calypso-dont-see-collision/#findComment-112938 Share on other sites More sharing options...
[Mi...] Posted November 1, 2018 Share Posted November 1, 2018 This is just a wild guess. Are the fixture pieces separate entities? Try going to CAD-Modification-Combine CAD Features. This will bring all the accessories into one entity. My thinking is that perhaps Calypso doesn't recognize other entities other than the part model. Link to comment https://qualityforum.zeiss.com/topic/20006-calypso-dont-see-collision/#findComment-112940 Share on other sites More sharing options...
[Er...] Posted November 1, 2018 Share Posted November 1, 2018 If I recall correctly, The detection of a collision is tracked at the ruby of the probe. So if your probe shaft is going thru but not the ruby, it wont detect it. But if a extension goes thru, it will detect that. Been a couple of years since I used the collision detection. I remember it as a wast of time. Simply because the tricky collisions isn't detected. How ever, this might have change in newer versions, as I said. Haven't used it for years. Link to comment https://qualityforum.zeiss.com/topic/20006-calypso-dont-see-collision/#findComment-112942 Share on other sites More sharing options...
[No...] Posted November 5, 2018 Share Posted November 5, 2018 I use simulation / collision detetction every now and then, but I've also come to the conclusion that it's not to be fully trusted. Expect it to follow the 80/20 rule: 80% of the collisions are detected correctly (on lowest speed setting), 20% are wrong or missed completely. False positives are often due to the simulation not working correctly. For instance, right after a probe change it likes to move right through the granite from below to the first point. Very realistic 🤣 I know that in some release they extended collision check to also include the whole(?) probe, probe head etc. I only remember that when I read of this improvement in the release notes, I was thinking: oh, so it didn't check for all this before? Well, thank you for the info... 🙄 Have you checked whether your fixture is marked as a part of the workpiece in the CAD hierarchy? Right click the entity in the hierarchy and see if workpiece is checked. This might influence collision detection (but I'm not sure). Link to comment https://qualityforum.zeiss.com/topic/20006-calypso-dont-see-collision/#findComment-112944 Share on other sites More sharing options...
