Radial Runout
Factor for Outlier remains at value 3, Include Adjacent Points is set to value 5.
No. Of iterations remains at the value 1.
Undulation per Revolution from 10 to 5000.
With ok steady!
In the settings for filters you have to set the "Undulations Per Revolution" to the correct value, this depends on the diameter of the cylinder.
< 8mm =15upr
8- 25mm =50upr
26 - 80mm =150upr
81 - 250mm =500upr
>250mm = 5000upr
https://qualityforum.zeiss.com/topic/20020-radial-runout/#findComment-113030
If they're on, they get applied. Do they change the result? It depends.
Different machining processes are liable to produce more outliers than others, better form than others, etc. Since Runout includes form in the results, I would think using established settings would help, especially on features with high form error.
https://qualityforum.zeiss.com/topic/20020-radial-runout/#findComment-113034
