[Ca...] Posted October 26, 2018 Share Posted October 26, 2018 I'm trying to recall data from a prior program revision with subsequent evaluation, and it's not working. I know Calypso can be sensitive when recalling data, but I think I've followed all the "rules". It says there is errors with references for all the characteristics. I'd REALLY like NOT spending 40 hours rerunning all these parts. Any suggestions? Running Caly 6.4 Link to comment https://qualityforum.zeiss.com/topic/20060-subsequent-evaluation/ Share on other sites More sharing options...
[Ri...] Posted October 27, 2018 Share Posted October 27, 2018 If the program you are using isn't identical to the program used when the measuring points were saved, you will get incomplete results. (Characteristics will not calculate). Link to comment https://qualityforum.zeiss.com/topic/20060-subsequent-evaluation/#findComment-113396 Share on other sites More sharing options...
[No...] Posted October 29, 2018 Share Posted October 29, 2018 You have to make sure all the features for which points were saved still exist and have not been renamed. That's because Calypso stores the points by feature name. Renamed features get not points and can't be evaluated, resulting in missing references. To check for the required feature names, rename the *.zmp file to *.zip and look at the file list in the archive. Link to comment https://qualityforum.zeiss.com/topic/20060-subsequent-evaluation/#findComment-113398 Share on other sites More sharing options...
