[Me...] Posted October 12, 2018 Share Posted October 12, 2018 Hey guys, I have a part drawing that has a straight line of holes. It states that it wants a comp TP (no datum references) for any 3 consecutive holes. Now I can make an individual alignment/position for each hole, but is there an easier way to do it? I have over 40 holes. Thanks in advance. Link to comment https://qualityforum.zeiss.com/topic/20136-composite-tp-for-any-3-consecutive-holes/ Share on other sites More sharing options...
[Jo...] Posted October 12, 2018 Share Posted October 12, 2018 I would just evaluate all the holes like any normal composite position tolerance. If the holes come out good, then they're good. If not, then there are some holes that don't meet spec and the part is bad. The "3 consecutive holes" note seems misguided. Link to comment https://qualityforum.zeiss.com/topic/20136-composite-tp-for-any-3-consecutive-holes/#findComment-113774 Share on other sites More sharing options...
[Me...] Posted October 13, 2018 Author Share Posted October 13, 2018 I believe it makes sense in this particular case. The "straight" line of holes tend to bend in and then back out. I believe this callout is an attempt to make sure the curved line of the holes isn't too severe. Link to comment https://qualityforum.zeiss.com/topic/20136-composite-tp-for-any-3-consecutive-holes/#findComment-113776 Share on other sites More sharing options...
[Jo...] Posted October 15, 2018 Share Posted October 15, 2018 If this is a composite position tolerance and there is no datum reference in the lower tier then the only thing being controlled is the spacing between the holes, not the orientation to any datums. What datum references are in the top tier? Link to comment https://qualityforum.zeiss.com/topic/20136-composite-tp-for-any-3-consecutive-holes/#findComment-113778 Share on other sites More sharing options...
[De...] Posted October 15, 2018 Share Posted October 15, 2018 It would seem to me that the primary purpose of this would be to maintain the alignment of any 3 consecutive holes to each other, and in this way limit the overall amount of 'twist' of the entire series of holes. If there is no Datum reference then the check is the orientation of the pattern to itself, or in other words it would check that the holes were in line. That said I cannot think of a great way to do the check other than creating something for each 'set' of holes. Link to comment https://qualityforum.zeiss.com/topic/20136-composite-tp-for-any-3-consecutive-holes/#findComment-113780 Share on other sites More sharing options...
[Me...] Posted October 16, 2018 Author Share Posted October 16, 2018 I ended up caving and literally making a separate alignment for each hole. It was a very fun few hours. Link to comment https://qualityforum.zeiss.com/topic/20136-composite-tp-for-any-3-consecutive-holes/#findComment-113782 Share on other sites More sharing options...
