[To...] Posted October 2, 2018 Share Posted October 2, 2018 Is anyone experiencing issues trying to add different RDS angles to a stylus system in Planner 6.6. After I add a stylus to the stylus list, I typically would select "Create New Stylus System" and then select "Update", which would prompt with list of new probes asking me which stylus they should be referenced from. That window is not popping up for me. So, I get a stylus system with all new probes in the positions from the styli list but they don't have any geometry values. Also, in simulation, my CAA version stylus system is not touching the part. ****Everything works fine in 6.4. **** (not true) I've actually re-created all of the stylus systems in SSC just in case there are any differences in the SSC files. Link to comment https://qualityforum.zeiss.com/topic/20222-creating-stylus-systems_planner_calypso-66/ Share on other sites More sharing options...
[Er...] Posted October 2, 2018 Share Posted October 2, 2018 6.6 is the worst release in 10 years. There are so many bugs that make the initial version unuseable for me. I think I have reported about 15 critical bugs, and there are atleast 15 other bugs that irritate me so much I cracked a keyboard.. There was no testning before release, mark my word on that! I went back to 6.4.something, And I might skip 6.6 compleatly, The only thing thats nice, is the new visuals.. Link to comment https://qualityforum.zeiss.com/topic/20222-creating-stylus-systems_planner_calypso-66/#findComment-114332 Share on other sites More sharing options...
[To...] Posted October 2, 2018 Author Share Posted October 2, 2018 I stand corrected. I just went through the same exercise on 6.4 and am seeing the same results. When using a probe at B90 or B-90, it appears to be 1 probe radius off in Z. Link to comment https://qualityforum.zeiss.com/topic/20222-creating-stylus-systems_planner_calypso-66/#findComment-114334 Share on other sites More sharing options...
[To...] Posted October 2, 2018 Author Share Posted October 2, 2018 Update.... After several attempts to resolve the problem, I finally fouled up the connection to my machine. Had to create a new machine tab and imported my SSC files and now it seems to be working correctly. Link to comment https://qualityforum.zeiss.com/topic/20222-creating-stylus-systems_planner_calypso-66/#findComment-114336 Share on other sites More sharing options...
[Ro...] Posted October 4, 2018 Share Posted October 4, 2018 Crap! I just put a ticket in to get both my seats upgraded to 6.6....... im gonna be screwed, i know it!! Link to comment https://qualityforum.zeiss.com/topic/20222-creating-stylus-systems_planner_calypso-66/#findComment-114338 Share on other sites More sharing options...
[No...] Posted October 4, 2018 Share Posted October 4, 2018 I never upgrade before at least SP1 or even SP2 is out, expecially when there are 100 new features. Exception: a parallel installation for testing purposes. My experience form past releases is this: Whenever they touched a feature that has been working perfectly before, they messed something up, which would typically take a long time to get fixed. Link to comment https://qualityforum.zeiss.com/topic/20222-creating-stylus-systems_planner_calypso-66/#findComment-114340 Share on other sites More sharing options...
