[Me...] Posted September 12, 2018 Share Posted September 12, 2018 First I'm a babe in the woods with Calypso, but I have 27 years programming experience with PCDmis. What I want to do here is very easily accomplished with a couple of mouse clicks in PCDmis so I have to believe that it can be done in Calypso as well. I'm using Calypso 2016. What I need to do is pick a point on the part CAD, flip the approach vector, add a 3mm feeler gap distance, and take that point on the gage surface. IS this possible with Calypso? I don't have gage CAD so I'm forced to use part CAD for this. Any and all help is 100% appreciated.. Bill Link to comment https://qualityforum.zeiss.com/topic/20318-measuring-a-gage-using-part-data/ Share on other sites More sharing options...
[Cl...] Posted September 12, 2018 Share Posted September 12, 2018 In the point feature there are IJK boxes, to reverse the vector just change the appropriate one from neg to pos, or vise versa. If the point doesn't need to be in exact XYZ coordinates, use a space point. If it does need to be exact, open a point feature and adjust the nominals accordingly. Then simply edit the direction by the offset amount. You ex Air Force? I worked on the F4 at Seymour Johnson AFB, 84 - 86 Link to comment https://qualityforum.zeiss.com/topic/20318-measuring-a-gage-using-part-data/#findComment-114900 Share on other sites More sharing options...
[Me...] Posted September 12, 2018 Author Share Posted September 12, 2018 Please sign in to view this quote. Thank you for the quick response. Yes ex Air Force. I worked on the F4 in the 33rd Tac Fighter WIng and 4485th TAWC at Eglin AFB from 76 to 81. Bill Link to comment https://qualityforum.zeiss.com/topic/20318-measuring-a-gage-using-part-data/#findComment-114902 Share on other sites More sharing options...
[Cl...] Posted September 12, 2018 Share Posted September 12, 2018 Environmental, F-111's. 48 CRS Raf Lakenheath 82-84. Thanks form your service! Link to comment https://qualityforum.zeiss.com/topic/20318-measuring-a-gage-using-part-data/#findComment-114904 Share on other sites More sharing options...
[Me...] Posted September 13, 2018 Author Share Posted September 13, 2018 Thank you for your service as well. I was Inertial Navigation and Weapons Delivery. The smell of burning jet fuel still brings back memories. Even commercial aviation fuel burning takes me right back. Man those were some good times. Three of my closest friends are guys that I served with. Bill Link to comment https://qualityforum.zeiss.com/topic/20318-measuring-a-gage-using-part-data/#findComment-114906 Share on other sites More sharing options...
[Cl...] Posted September 13, 2018 Share Posted September 13, 2018 Same here. I keep in touch with several friends station together at Lakenheath 35 yrs ago! Link to comment https://qualityforum.zeiss.com/topic/20318-measuring-a-gage-using-part-data/#findComment-114908 Share on other sites More sharing options...
