[Me...] Posted June 21, 2018 Share Posted June 21, 2018 It has been many years since I had to set up a new Disc probe and have forgotten how I should do the qualification on it. We will be using it on our Contura with the articulating head and I was hoping to be able to qualify it in all 5 axis (-Z,+Y,-Y,+X,&-X). If I remember correctly it is not viable to scan for qualification but only taking point. If anyone can give me some help on this (such as probe direction and such) it would be much appreciated. Link to comment https://qualityforum.zeiss.com/topic/20346-disc-prob-qualification/ Share on other sites More sharing options...
[Mi...] Posted June 21, 2018 Share Posted June 21, 2018 I only use mine in the Z direction, but the way I calibrate mine, is I touch on the top of the qual sphere, then drop down to the equator of the sphere, take 4 points, then move the disc up off the center and take 4 more hits.(Manual Mode) I then let calypso run it After the machine does this, I will take a calibrated ring gage and measure the ring gage with the disc. I will change the disc diameter till it matches what the lab says the ring gage measured. This has worked for me going on 5 yrs. Never got into discs till I got here. Again this is the way I do it. Right or wrong lol. Link to comment https://qualityforum.zeiss.com/topic/20346-disc-prob-qualification/#findComment-115188 Share on other sites More sharing options...
[De...] Posted June 21, 2018 Share Posted June 21, 2018 I am fairly sure that Zeiss does not support the use of Disc probes on the Contura. That being said, we always used ring gages and changes the values to match the ring gage actual values. Link to comment https://qualityforum.zeiss.com/topic/20346-disc-prob-qualification/#findComment-115190 Share on other sites More sharing options...
[Me...] Posted June 21, 2018 Author Share Posted June 21, 2018 Why would they not support the use of a Disc Probe on the Contura? They sell Disc Probes. Link to comment https://qualityforum.zeiss.com/topic/20346-disc-prob-qualification/#findComment-115192 Share on other sites More sharing options...
[To...] Posted June 21, 2018 Share Posted June 21, 2018 Please sign in to view this quote. Zeiss does not support disc probes on XXT. The machine type doesn't matter. Link to comment https://qualityforum.zeiss.com/topic/20346-disc-prob-qualification/#findComment-115194 Share on other sites More sharing options...
[Me...] Posted June 21, 2018 Author Share Posted June 21, 2018 Do we know why? Link to comment https://qualityforum.zeiss.com/topic/20346-disc-prob-qualification/#findComment-115196 Share on other sites More sharing options...
[To...] Posted June 21, 2018 Share Posted June 21, 2018 Please sign in to view this quote. GOOD QUESTION Link to comment https://qualityforum.zeiss.com/topic/20346-disc-prob-qualification/#findComment-115198 Share on other sites More sharing options...
[Jo...] Posted September 10, 2018 Share Posted September 10, 2018 Please sign in to view this quote. Which version of the software are you using? We are not being able to qualify manually using calypso 6.4 In the "Probing System qualification" menu there is no Manual mode option. If we go through the menu "Stylus" -> "Manual Path" when trying to manually probe the calibration sphere an error message pops-out saying that the probe is not qualified. Thanks in advance Link to comment https://qualityforum.zeiss.com/topic/20346-disc-prob-qualification/#findComment-115200 Share on other sites More sharing options...
[Mi...] Posted September 10, 2018 Share Posted September 10, 2018 I am using 2018/6.6 I have the manual mode option.. Link to comment https://qualityforum.zeiss.com/topic/20346-disc-prob-qualification/#findComment-115202 Share on other sites More sharing options...
