[Me...] Posted August 23, 2018 Share Posted August 23, 2018 We upgraded to Calypso 2018 yesterday. Three CMMs. On one of them, the probe rack has mysteriously lowered by about 8mm (or so it seems). We can't change out probes. The head is coming in too high. Is there a global setting that I need to re-set? If not, did they move the rack alignment procedure? I can't seem to find it. Frustrated... Link to comment https://qualityforum.zeiss.com/topic/20454-2018-upgrade/ Share on other sites More sharing options...
[Me...] Posted August 23, 2018 Author Share Posted August 23, 2018 Did you try defining the holder location again? I only have 2017, and it is in the Automatic stylus change window, so if you know where it was in there, then they may have moved it. Link to comment https://qualityforum.zeiss.com/topic/20454-2018-upgrade/#findComment-115964 Share on other sites More sharing options...
[De...] Posted August 23, 2018 Share Posted August 23, 2018 Just saying, information on machine type might be helpful, not sure since all we have are prismo's but i'm sure different machines probably have different procedures for the rack. Hopefully someone else has run into this before and has an answer. If not, if you have the old machine config (hopefully it was backed up), usually you can copy it over the new one in order to upgrade once the install is complete - might be worth getting Zeiss on the phone to walk you through it if you have a copy of the old config folder. Link to comment https://qualityforum.zeiss.com/topic/20454-2018-upgrade/#findComment-115966 Share on other sites More sharing options...
[Me...] Posted August 23, 2018 Author Share Posted August 23, 2018 That's where I thought it was, but I'm looking for something called 'rack alignment' or 'stylus holder alignment' or something along those lines. I'm going from memory here, so don't quote me. The only thing that I see in the Auto stylus change window that makes sense is the 'Approach parameters' in the Changer section. But I don't think that is what I want. I need to re-align the stylus holder rack (evidently). It seems strange to me that of the 3 CMMs that we upgraded yesterday, this one machine is the only one that has this issue. Link to comment https://qualityforum.zeiss.com/topic/20454-2018-upgrade/#findComment-115968 Share on other sites More sharing options...
[Me...] Posted August 23, 2018 Author Share Posted August 23, 2018 ...Contura G2, Vast XXT head... Link to comment https://qualityforum.zeiss.com/topic/20454-2018-upgrade/#findComment-115970 Share on other sites More sharing options...
[Me...] Posted August 23, 2018 Author Share Posted August 23, 2018 There you go, that's from 2017 at least. Select Define holder location, that's what I used, but if you are talking about something else, not sure then, sorry.stylus.png Link to comment https://qualityforum.zeiss.com/topic/20454-2018-upgrade/#findComment-115972 Share on other sites More sharing options...
[Te...] Posted August 23, 2018 Share Posted August 23, 2018 In the changer drop down it is define holder location. It is the same for 2018 just checked. Link to comment https://qualityforum.zeiss.com/topic/20454-2018-upgrade/#findComment-115974 Share on other sites More sharing options...
[Me...] Posted August 23, 2018 Author Share Posted August 23, 2018 All three of you are right. I'll have to claim 'Senior Moment' to get out of this one. Once I tried it, things looked familiar and I got it done. I still don't know why this would change after an upgrade. Maybe there will be more surprises for us over the next few weeks! Thanks to Ted, Dave and Derek! Link to comment https://qualityforum.zeiss.com/topic/20454-2018-upgrade/#findComment-115976 Share on other sites More sharing options...
[Me...] Posted August 23, 2018 Author Share Posted August 23, 2018 Please sign in to view this quote. Can't wait to be able to use that defense. No problem though. Link to comment https://qualityforum.zeiss.com/topic/20454-2018-upgrade/#findComment-115978 Share on other sites More sharing options...
