Flatness
Not really a Calypso issue but..........
I have a part here that is called out as 0.8 +/- 0.02. So 1.00mm max. Also has a flatness call out of 0.25. I have Eng's here saying that they can use the 0.25 and add it to the 0.8 tolerance to help in sorting these parts for thickness. Some might be over the 1.00 mm. I know profile callout can play a role but a flatness callout?
Im not so sure about this but I cant find any ref material to fight them. Still looking
Thoughts?
https://qualityforum.zeiss.com/topic/20462-flatness/
I should clarify that: It's not just because the form tolerance is "wider". The application of flatness in this case "widens" the size envelope by the flatness tolerance. So, if the size is really 0.8 +/-0.2 (max 1.00) and the flatness tolerance is 0.25, then it must fit within an envelope of 1.25.
https://qualityforum.zeiss.com/topic/20462-flatness/#findComment-116012
The way that I interpret 5.4.2 is that flatness must be less than the size tolerance. If the independency symbol is used than the flatness tolerance may be greater than the size tolerance. So, I think there should be an independecy symbol on the print or else the flatness must be with the size. If the size tolerance is +/-.2 then you have .4 that you can fit .25 flatness within.
https://qualityforum.zeiss.com/topic/20462-flatness/#findComment-116014
This is actually important. If the flatness is called out with a leader line directed at a surface then the value cannot be more than the size tolerance. If the callout is associated with the size dimension then the callout is fine and the value is added to the MMC size of the part to determine the outer boundary.
https://qualityforum.zeiss.com/topic/20462-flatness/#findComment-116020
Okay, so if there is a potential of approving parts that will not fit in the hidden groove, then a prudent approach for the evaluation is warranted. 40 micron tolerance for size is snug. Saying that the print allows these parts to exceed that tolerance by 5 times that is a little nuts.
https://qualityforum.zeiss.com/topic/20462-flatness/#findComment-116038
Well there certainly seems to be a lot of assumptions flying around as we really don't know the entire story. I was making the assumption they may have purchased wire with a specified tolerance and were only forming the rings. If they are manufacturing the wire, then I agree the tolerance may be important.
https://qualityforum.zeiss.com/topic/20462-flatness/#findComment-116044
Yeah...I definitely jumped on the assume-it's-Y14.5 bandwagon. I would guess that's what your engineers did, too, but that's just speculation. 😉
While all the Y14.5 talk wasn't really applicable to the OP, it did throw some light on part of that standard that doesn't usually see the light of day.
BTW, Mike, don't forget to toggle the switch in Calypso so that it evaluates according to ISO instead of ASME. 🤣
https://qualityforum.zeiss.com/topic/20462-flatness/#findComment-116046
This part is actually bent into a "C" shape from our supplier. This in turn is inserted/pressed into a ID. The ID has a groove cut into it about 2 mm down. This part springs back if you will into that groove. So its a "spring washer" as we call it.
They are still sorting with a 1.05 tolerance on the part which does not make sense to me!
https://qualityforum.zeiss.com/topic/20462-flatness/#findComment-116048
