[da...] Posted August 14, 2018 Share Posted August 14, 2018 Have been trying to get this to work but having no success, anyone have some pointers for me? it would be handy on a part I am doing right now. ' thanks Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/ Share on other sites More sharing options...
[Cl...] Posted August 14, 2018 Share Posted August 14, 2018 3 features needed. For example and in this order; a 2d curve, 2d line, circle. Start with a curve, recall the curve points needed to create the line and circle = Kink point. Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116162 Share on other sites More sharing options...
[da...] Posted August 14, 2018 Author Share Posted August 14, 2018 i don't have a circle available, looking to get the point between two planes, they are only .009 apart. Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116164 Share on other sites More sharing options...
[Cl...] Posted August 14, 2018 Share Posted August 14, 2018 Can you post a pic? Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116166 Share on other sites More sharing options...
[Cl...] Posted August 14, 2018 Share Posted August 14, 2018 Both planes at different heights? I'm thinking three lines constructed from a curve? So for example two lines in X & the 3rd is the dividing line in Z. This looks like a stair step? Is this your situation? Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116168 Share on other sites More sharing options...
[da...] Posted August 14, 2018 Author Share Posted August 14, 2018 this is what I am dealing with.. Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116170 Share on other sites More sharing options...
[Cl...] Posted August 14, 2018 Share Posted August 14, 2018 So, if I'm in front of the machine and this is what I see, in this view, you are working in the XY work plane? How much land is available on that vertical wall? If it's big enough why don't you just probe the wall? I'm betting you tried that already, why else would you be trying a kink point? Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116172 Share on other sites More sharing options...
[Ri...] Posted August 14, 2018 Share Posted August 14, 2018 I don't think kink will work here. Step Point might do the trick though and that's going to be an easier construction to build. A 2D Line that travels over the break in the two planes then one of the planes for your Datum. Your Step Angle will be 90 degrees. Make sure you use a Stylus that is not so small that it "catches" on the step or one that is so large that it fails to detect the step. I'm just guessing but somewhere between 1.5mm and 3mm ought to do the job nicely. Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116174 Share on other sites More sharing options...
[da...] Posted August 14, 2018 Author Share Posted August 14, 2018 .009 step, will try step point, have only used that once before, but worth a try Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116176 Share on other sites More sharing options...
[Ri...] Posted August 14, 2018 Share Posted August 14, 2018 Scan speeds are critical here. Keep it slow. Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116178 Share on other sites More sharing options...
[da...] Posted August 14, 2018 Author Share Posted August 14, 2018 its not going to give me a result in simulation mode is it? am programming offline Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116180 Share on other sites More sharing options...
[Ri...] Posted August 14, 2018 Share Posted August 14, 2018 It might, but I wouldn't bet the farm on it. Do you have a Stylus System built in simulation for this? That would be your best chance at getting a result in Simulation. Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116182 Share on other sites More sharing options...
[Ro...] Posted August 15, 2018 Share Posted August 15, 2018 Def use step point, with a 1mm styli running slow. You wont get a result in simulation, because you're not actually finding the drop off. I have used step points with plain old Lines in the past very successfully. and only 1.5mm long, so i could afford to scan slowstep point1.jpg Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116184 Share on other sites More sharing options...
[da...] Posted August 15, 2018 Author Share Posted August 15, 2018 Trying step point, but getting the ol pink result, is this because I am running in simulation, is it not going to give a result unless it actually measures the part? hate to do bunch of these and then have them not work. but if you think they will will go ahead. and we shall see. I am using a 2 d line, scanning slow, and one of the planes for the datum. the line is angled of course . Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116186 Share on other sites More sharing options...
[da...] Posted August 15, 2018 Author Share Posted August 15, 2018 thanks Robert you answered me while I was typing the question, nice job! thanks for all the help it's appreciated Link to comment https://qualityforum.zeiss.com/topic/20476-how-to-use-a-kink-point/#findComment-116188 Share on other sites More sharing options...
