[La...] Posted July 27, 2018 Share Posted July 27, 2018 Our Contura G2 with an XT Gold scan head when running Calpyso 5.6 was set up when features extracted from Solid Models, they had an inspection path automatically set with a certain number of probing points for the scan paths. 1_ Since upgrading to Calypso 6.4, (which we did because be added a smaller table Contura) when I extract features from S/Ms, planes do not have scan paths on them like they did with 5.6... why not? 2_ How do we set the number of points to be collected with the different types of scans? I thought I knew where to go to change the settings to make the features import set the way we want them setup, but obviously I don't. I am always grateful for help from the forum, so thank you in advance for your helpful input. Link to comment https://qualityforum.zeiss.com/topic/20550-extracting-features-from-sm/ Share on other sites More sharing options...
[De...] Posted July 27, 2018 Share Posted July 27, 2018 Sounds like someone went through the time to set the defaults up in save / load defaults on the old system and those settings were not copied over to the new setup. You can setup how extracted features will be extracted / measured in the menu - Resources -> Save / Load Defaults You might also want to look in the menu - Extras -> Settings -> Measurement Tab under methods if needed to switch from single points to scan paths. Link to comment https://qualityforum.zeiss.com/topic/20550-extracting-features-from-sm/#findComment-116732 Share on other sites More sharing options...
