[Hu...] Posted July 13, 2018 Share Posted July 13, 2018 I would like to know when I uninstall Calypso 5.8 which we currently have and upgrade to version 6.4 will our automatic stylus system change data stay the same or will we have to start from scratch. Thanks Jim Link to comment https://qualityforum.zeiss.com/topic/20586-upgrade-from-calypso-58-to-64/ Share on other sites More sharing options...
[To...] Posted July 13, 2018 Share Posted July 13, 2018 5.8 to 6.4 should be a relatively smooth process. Your probes, probe rack, machine info is all stored in the C:\users\public\documents\Zeiss\Calypso\config. At a minimum, I would create a copy of the config folder and save it on your desktop or some other location. If you really want to be cautious, you could copy the entire Zeiss folder and store it somewhere. I typically highlight the Zeiss folder and do Ctrl-C, then Ctrl-V. You'll end up with a folder called Zeiss - Copy. In all of my upgrades with the current folder architecture, I've not had any issues. But better to be safe than sorry. Link to comment https://qualityforum.zeiss.com/topic/20586-upgrade-from-calypso-58-to-64/#findComment-116930 Share on other sites More sharing options...
[Mi...] Posted July 13, 2018 Share Posted July 13, 2018 Just to add this... I do most of these. When I did the UG last yr, Calypso changed my qual sphere from 14.9928 to 15.00 and everything was off by the .008. lesson LEARNED LOL WINDOWS 7-CALYPSO 5.6 OR NEWER FILE PATHS: C:\Users\Public\Documents\Zeiss\CALYPSO\Config\ C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\inspections\ C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\basesystems\ C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\ C:\Users\Public\Documents\Zeiss\CALYPSO\protocol\protform\ Link to comment https://qualityforum.zeiss.com/topic/20586-upgrade-from-calypso-58-to-64/#findComment-116932 Share on other sites More sharing options...
[To...] Posted July 13, 2018 Share Posted July 13, 2018 Mike, After some upgrades, I've seen a window pop up on the first run of Calypso, that asks you if you want to transfer all of your settings, programs, etc., to the new version. Did you possibly select "no"? Just thinking out loud. Link to comment https://qualityforum.zeiss.com/topic/20586-upgrade-from-calypso-58-to-64/#findComment-116934 Share on other sites More sharing options...
[Mi...] Posted July 13, 2018 Share Posted July 13, 2018 Yeah I said yes. Mike Staines was in here few months and he also heard of a few instances that has happened. My fault for not doing the BU. Link to comment https://qualityforum.zeiss.com/topic/20586-upgrade-from-calypso-58-to-64/#findComment-116936 Share on other sites More sharing options...
[Hu...] Posted July 13, 2018 Author Share Posted July 13, 2018 Thanks guys for the info, I will upgrade sometime later in the day. Thanks Jim Link to comment https://qualityforum.zeiss.com/topic/20586-upgrade-from-calypso-58-to-64/#findComment-116938 Share on other sites More sharing options...
[An...] Posted July 14, 2018 Share Posted July 14, 2018 Hello Jim, You can also do a Parelelle installation, so you can work with the new software and if something is wrong, you can just copy the changes to the old version. I always leave the old version on it for a few weeks, if the new version works without problems, only then do I delete the old version! Link to comment https://qualityforum.zeiss.com/topic/20586-upgrade-from-calypso-58-to-64/#findComment-116940 Share on other sites More sharing options...
[Me...] Posted July 20, 2018 Share Posted July 20, 2018 I just caught this post. This is one reason I don't uninstall the previous ver. Until I know things are running smoothly, (which in times past haven't), I keep the older version around. Link to comment https://qualityforum.zeiss.com/topic/20586-upgrade-from-calypso-58-to-64/#findComment-116942 Share on other sites More sharing options...
