[Ja...] Posted June 25, 2018 Share Posted June 25, 2018 Before I started the CMM was set up and the name of the master probe was changed. Is there a way to fix it? Link to comment https://qualityforum.zeiss.com/topic/20674-fix-the-master-probe/ Share on other sites More sharing options...
[Da...] Posted June 26, 2018 Share Posted June 26, 2018 Can you give more details ? Picture ? Link to comment https://qualityforum.zeiss.com/topic/20674-fix-the-master-probe/#findComment-117556 Share on other sites More sharing options...
[No...] Posted June 26, 2018 Share Posted June 26, 2018 Is it even possible to change that name? I didn't know that 😕 Link to comment https://qualityforum.zeiss.com/topic/20674-fix-the-master-probe/#findComment-117558 Share on other sites More sharing options...
[To...] Posted June 26, 2018 Share Posted June 26, 2018 I'm going to go out on a limb and guess she is talking about the probe rack holder for the MasterProbe. Link to comment https://qualityforum.zeiss.com/topic/20674-fix-the-master-probe/#findComment-117560 Share on other sites More sharing options...
[Ja...] Posted June 26, 2018 Author Share Posted June 26, 2018 The ID for the sensor on the Master Probe is this I'm not used to seeing the styli available called thatMasterProbe.PNG Link to comment https://qualityforum.zeiss.com/topic/20674-fix-the-master-probe/#findComment-117562 Share on other sites More sharing options...
[To...] Posted June 26, 2018 Share Posted June 26, 2018 The 1 stylus is pretty typical. The Rack stylus is used for locating of the probe rack, which is not used very often. Link to comment https://qualityforum.zeiss.com/topic/20674-fix-the-master-probe/#findComment-117564 Share on other sites More sharing options...
[Te...] Posted June 28, 2018 Share Posted June 28, 2018 What happens is it defaults to the Stylus Rack because it is A90 B0. So when you go to Reference Sphere position it says the MasterProbe is needed. Go to the drop down and select 1 and you will be fine. I usually create a separate Stylus System called Probe Rack (Masterprobe at A90 B0) so this doesn't happen to me any more. Link to comment https://qualityforum.zeiss.com/topic/20674-fix-the-master-probe/#findComment-117566 Share on other sites More sharing options...
