Break Statement for Looped Base Alignment
When you enter the break statement in your loop for the base alignment is it always in metric?
baseSystem().valueA<0.005 I am guessing it is always in metric but just would like some verification.
I used 0.0002 in an inch program and it runs all 5 loops when normally in a metric program 3 is the most it runs.
I know PCM for CMM Position is always in metric so it would stand to reason that it is always metric.
Thanks
It's been a while since I've tested it but, I believe it "now" is whatever unit you use it in.
It didn't used to be that way but, at some revision they changed it.
Hey Ted,
valueA is not an inch/metric number, it's the total transformation of the new alignment from where Calypso expected to find it. It uses a matrix to combine X, Y, & Z translation with rotation about X, Y, & Z so it's kinda inch-degrees or millimeter degrees. Because of this if you convert the 0.005 used in a metric program to 0.0002 for an inch program you are actually setting the threshold a lot lower...meaning you want a tighter alignment. For inch programs, I usually go with 0.002 which is 0.005/25.4*10. Depending on your part this may be too loose or tight. Run the alignment 5 times without a break condition & check the delta values in the default printout. It should stabilize after 2-3 runs & give you an idea of where to set it. Feel free to give me a call or shoot me an email if you want.
According to my sources, from version 5.4 on, this value was based on the unit of measure of the program.
I am fairly sure that the A value is the delta value based on the unit of measure your plan is in. We typically use 0.001" and most programs go through 3 iterations in that loop. If you go more than 5 your base alignment is probably not sufficient, or at least that has been my experience.
