[Da...] Posted May 18, 2018 Share Posted May 18, 2018 Greetings, Does anybody know if there is a stylus system holder that is available for the O-INSPECT that will accommodate more than three stylus systems? I unfortunately have a complex part that may require five. In the Zeiss catalog, they only show the standard three bay holder. I have been manually inserting a fourth system, but that requires me to stay by the machine at intervals during the program run. If anybody has any info on this, it would be greatly appreciated. Thanks, Dan Link to comment Share on other sites More sharing options...
[No...] Posted May 22, 2018 Share Posted May 22, 2018 The Zeiss shop (shop.metrology.zeiss.de) sells single XXT holders, but I don't know if they can be attached to the standard holder. Would five holders even fit on the machine? On our OI 322 the maximum possible would be four - unless stacked in Z, but I wouldn't want to try that on a 322. Link to comment Share on other sites More sharing options...
[38...] Posted June 4, 2018 Share Posted June 4, 2018 Weird, they used to offer a 6 bay changer for OI, looks like it's no longer available in the online shop. Only 5 were available to access by CNC, but the 6th bay was a good slot for the Master Probe. Link to comment Share on other sites More sharing options...
[Da...] Posted June 5, 2018 Author Share Posted June 5, 2018 Wow! I really wish they still offered that. It would have worked out great for a series of parts that i'm inspecting. I was just trying to eliminate using 1mm tip styli systems for the entire part. I guess i'll have to stick to the manual load method for the time being. Thanks for input. Dan Link to comment Share on other sites More sharing options...
[38...] Posted June 5, 2018 Share Posted June 5, 2018 https://us.probes.zeiss.com/en/5%2B1-fo ... _4230.html Look what I found! Link to comment Share on other sites More sharing options...
[Da...] Posted June 5, 2018 Author Share Posted June 5, 2018 Awesome! You're the best! Thank you so much for finding this. Should let me start the program and forget it. 😃 Dan Link to comment Share on other sites More sharing options...
