Radius instead of Diameter
Hello,
I have a program that is written to measure conical grooves and then the drawing calls out the center of the conical groove with a dimension from the center of the round part. I can ask for the position of the intersection of the two cones but this gives me a Diameter and to conform to the drawing I need a Radius. It would be a good addition on the tolerance box area to add a check box to apply radius or diameter.
Hopefully someone can point me in the right direction.
Thanks
https://qualityforum.zeiss.com/topic/20840-radius-instead-of-diameter/
