[Ca...] Posted May 22, 2018 Share Posted May 22, 2018 About a week ago, Calypso started reverting to default settings over night. All measurements are in metric, 4 decimal places, blank startup page, no programs listed in the history. It's like a fresh install. I haven't changed anything. We have in-house IT for the PICNIC's, and external IT for the really heavy lifting. Everyone states nothing has changed. Any guesses as to why my settings aren't sticking? Link to comment https://qualityforum.zeiss.com/topic/20862-calypso-reverting-to-defaults/ Share on other sites More sharing options...
[Me...] Posted May 22, 2018 Share Posted May 22, 2018 I'm not sure if Calypso is capable of running over a network or not, but just curious, is your computer a terminal connecting to the network, or are your config files located on a network? Link to comment https://qualityforum.zeiss.com/topic/20862-calypso-reverting-to-defaults/#findComment-118706 Share on other sites More sharing options...
[Ca...] Posted May 22, 2018 Author Share Posted May 22, 2018 Calypso is installed on a computer, not a network. I have 2 computers, one for the CMM, the other is for offline programming. The online (CMM) seat isn't having any problems. Link to comment https://qualityforum.zeiss.com/topic/20862-calypso-reverting-to-defaults/#findComment-118708 Share on other sites More sharing options...
[Me...] Posted May 22, 2018 Share Posted May 22, 2018 Hmm, okay, I am not sure then, I don't have an offline seat, so I don't have much of a guess Link to comment https://qualityforum.zeiss.com/topic/20862-calypso-reverting-to-defaults/#findComment-118710 Share on other sites More sharing options...
[No...] Posted May 22, 2018 Share Posted May 22, 2018 If everyone's stating nothing has changed, then usually something HAS changed 😉 I'd take a look at the permissions of the config folder first. Many of the settings you mention are stored in a number of files named 'values' (scattered over different subfolders). Check if they exist, their date of last modification and the permissions. Link to comment https://qualityforum.zeiss.com/topic/20862-calypso-reverting-to-defaults/#findComment-118712 Share on other sites More sharing options...
[Ja...] Posted May 22, 2018 Share Posted May 22, 2018 I have a similar issue with mine. Sometimes it will give me no history or a history files from calibration on the welcome screen. In each case I have had to change my environment to Inches from mm. My tech said it could be possible due to still having prior versions installed. I haven't delved into it much since it seems to be a rare occurrence. Link to comment https://qualityforum.zeiss.com/topic/20862-calypso-reverting-to-defaults/#findComment-118714 Share on other sites More sharing options...
[Me...] Posted May 22, 2018 Share Posted May 22, 2018 Actually I had a thought. When I recently upgraded to 2017, the file path changed and I had multiple folders, and when I went to load Calypso, even importing data and moving my backup folders I still had a blank slate, even no stylus systems. If you go to Extras>Settings>Miscellaneous>Internals and see if the file path name matches what you're supposed to be using? I believe Norbert's theory as well, so maybe it's a start. Link to comment https://qualityforum.zeiss.com/topic/20862-calypso-reverting-to-defaults/#findComment-118716 Share on other sites More sharing options...
