[Cl...] Posted May 21, 2018 Share Posted May 21, 2018 I am scanning several 2d curves. All curves have the same settings; step width, retract/approach, comparable speeds. The only difference that I can see is that they are all different lengths. One of the shorter curves scans fine, but when it's done scanning, it stops, doesn't go the +Z clearance, add activates the red light. I am at a loss, as to why? Any ideas? Link to comment https://qualityforum.zeiss.com/topic/20878-curve-problem/ Share on other sites More sharing options...
[Ja...] Posted May 21, 2018 Share Posted May 21, 2018 Did you check the vector direction? That catches me off guard sometimes because you just don't expect it to be in the direction of the model. Link to comment https://qualityforum.zeiss.com/topic/20878-curve-problem/#findComment-118772 Share on other sites More sharing options...
