[Da...] Posted May 14, 2018 Share Posted May 14, 2018 Hi guys. Anyone knows why I can't switch to position options ? I need to check diameter(or distance) in fixed place on the cone. I have done alignment with intersection plane. Another probelm is why I have two different results between using 'cone addition' and intersect therotical lines with cones (x4) and then create a circle. Link to comment https://qualityforum.zeiss.com/topic/20922-cone-addition/ Share on other sites More sharing options...
[Da...] Posted May 14, 2018 Share Posted May 14, 2018 You can get a diameter at a plane. But you are asking for a position at a plane. The position IS the plane. As far as the difference between an actual cone ( 2 to 3 circle paths ) and an angled series of 4 line intersections, The cone is a more complete check of the feature, It uses a large number of points to construct a 3d feature. The 4 points will not reflect a possible out of round condition as well as the cone feature. So if there is a fair amount of form error the 2 methods won't match very well. Link to comment https://qualityforum.zeiss.com/topic/20922-cone-addition/#findComment-119030 Share on other sites More sharing options...
[To...] Posted May 15, 2018 Share Posted May 15, 2018 In order to change from position to diameter, unselect the plane from the "or at" feature Link to comment https://qualityforum.zeiss.com/topic/20922-cone-addition/#findComment-119032 Share on other sites More sharing options...
[Da...] Posted May 15, 2018 Author Share Posted May 15, 2018 Yes of course, thank you. I have not been using calypso for a while now and I keep forgetting. This forum is so useful thanks ! Link to comment https://qualityforum.zeiss.com/topic/20922-cone-addition/#findComment-119034 Share on other sites More sharing options...
