[Da...] Posted May 14, 2018 Share Posted May 14, 2018 Hi guys. Anyone knows why I can't switch to position options ? I need to check diameter(or distance) in fixed place on the cone. I have done alignment with intersection plane. Another probelm is why I have two different results between using 'cone addition' and intersect therotical lines with cones (x4) and then create a circle. Link to comment Share on other sites More sharing options...
[Da...] Posted May 14, 2018 Share Posted May 14, 2018 You can get a diameter at a plane. But you are asking for a position at a plane. The position IS the plane. As far as the difference between an actual cone ( 2 to 3 circle paths ) and an angled series of 4 line intersections, The cone is a more complete check of the feature, It uses a large number of points to construct a 3d feature. The 4 points will not reflect a possible out of round condition as well as the cone feature. So if there is a fair amount of form error the 2 methods won't match very well. Link to comment Share on other sites More sharing options...
[To...] Posted May 15, 2018 Share Posted May 15, 2018 In order to change from position to diameter, unselect the plane from the "or at" feature Link to comment Share on other sites More sharing options...
[Da...] Posted May 15, 2018 Author Share Posted May 15, 2018 Yes of course, thank you. I have not been using calypso for a while now and I keep forgetting. This forum is so useful thanks ! Link to comment Share on other sites More sharing options...
