Where is setting for how you start a program?
Thanks Tom,
Yep that's it.
It seems it fixed itself by opening another program with the previous program opened.
I always close the program I'm working on before opening another.
But yes, those were the settings.
I just started running 6.4 this morning so I'm sure there are other Qs coming.
I also put in .04 as suggested by Zeiss and will follow up later with .08.
Thanks again
It appears I'm not the only one with this problem. I installed 6.4 last week in another machine and the same thing happened again. Only this time it would not let go. I called Zeiss and I had a tech log in and he saw what was going on.
It appears that since I do not uninstall the previous ver., (6.2), their may have been a conflict.
He is just guessing.
What he did was in "extras-setting-environment-paths" he changed the default path from "folder/folder/Calypso6.4/etc."
to "folder/folder/Calypso6.2/etc" and applied that. It went to the proper folder "inspections. Then he changed it back and that worked.
He is sending it to Germany as a glitch.
So that's that.
